We picked up a SN SJ with some nice parts on it. Previous owner test rode, ran fine, started when I got there, ran fine, started it a few times briefly after getting it home.
Went to start it last nite, and it started for about 2 seconds then cut out. The motor cranks but appears to be no spark. ebox was just recently sealed, mounted, and the bolts were turfed over, so I'm trying to see if there are other testing options before ripping the turf off to pull the coil.
touched plugs to head bolts, couldn't see any visual spark while cranking..both wires
put an in line spark tester in while cranking, no light whatsoever on either plug/wire
I also pulled both boots off, clipped the wires fresh and retried. I even tried touching the bare clipped wire to the tip of the plug and couldn't see spark.
I was told it could be the start stop switch. I disconnected the black and white start stop switch connector from the ebox and still had no spark.
Is there any more tests I can do on the start stop switch OR on the plug wires before I rip the turf off?
THANKS GUYS
pic shows the fresh wire I exposed. no spark while touching head bolt, plug tip, or even metal on test light while it was connected to spark plug
THANKS GUYS
