- Canada, Grimsby ON
i have a 91 sueptjet with a 760 swap and it has a type 4 dry pipe and I don't know how the water lines are supposed to be routed, my friend who is a two stroke guru helped tune my ski after I did a carb kit, and he said the water lines are routed weird what looks to him he doesn't know how these are supposed to be routed but it has one pisser and it doesn't shoot just water it's a mixture of air and water, not a steady stream which he thought maybe head gasket was gone but he said it's really fast and it performs like the head gasket is fine so I'm hoping someone here knows how a factory type 4 dry pipe is routed so I can check mine. I'm gonna pressurize the water jackets and see if the head gasket is good in a few days but I read how water routing can make or break a setup so I'm curious to see how it's supposed to be routed. I'm new to jet skis so I don't know much, I appreciate the helps. Thanks in advance!
