- Saskatchewan
Yes I'm told that's all rrp used under the original foam so I'm going thicker9mm under our feet.Seems like you would want it thicker?
1inch underpad the whole tray, then cover with the diamond turf u got. I ordered mine like this from factory, i think its an extra 50 bucks or somethingYes I'm told that's all rrp used under the original foam so I'm going thicker
First go at holds and turfing last year. Didn't really pay attention to the way the diamonds were going when I made the cuts and templates on the smooth side of the turf but meh could of turned out way worse. 18mm on tray 18mm in holds sanded to fit my riding shoes. Theae holds are HUGE and require 18mm foam forsure but once sanded to fit they are comfy. I can't imagine having less paddingEver smash your feet on the gray parts?
How do you find the 1" pad when adjusting your holds? do they still go up plenty to fit your feet properly? I'm just about to order some under pad and wondering if i should go 18 or 28 ThanksI just returfed my tray last december i think. Its 1 inch underpad with a layer of old waffle and then a new layer on top. Its still holding up good, i need to redo my footholds pretty bad tho.
Then i just started this haggard square build yesterday. Took the turf off today and trays all full of pinholes, leaky bondrail and bad scupper lol
Footholds look nice tho
What you guys running on the rickter trays? Heard factory is 9mm. My original turf is shredded under the holds. Just picked up a sheet of molded black turf to take care of it. Bump this thread back up its awesome!
I never even though about going right over it. Did you have to smooth the old diamonds off for it to adhere properly or was it fine? Feels like some one buttered my tray mines soo bad even though it looks fineOnce upon a time when I had my rickter I just turfed over the rickter turf. Added a rear kicker and a front foothold. Totally transformed it into a controllable ride. Original turf from 2012 was way to slippery.
Sent from air blair cell yo
Great idea on the poster board.Here are some pictures of my first full turf job on a stand up ski . I used poster paper to make templates to cut the turf. I put 26 mm padding in the tray and shaped a small kick tale on the rear. Did the rails too.
