Freakrider
X247
- Tampa Bay area
Stock trim ring with oem flow guard attached with a SS homemade bracket.
Did you have any issues with stock nozzle being bored to 91.5 ? I have mine at 90.35.I've got up to 90.5mm max bore on a stock nozzle. Im also considering trying to reinforce the nozzle with glass and carbon and then boring it bigger to see if a larger nozzle combo works better...ex 12/18 prop with 89mm nozzle vs 13/19 prop with 93mm nozzle. I'm curious if anybody has done any testing like this and what their results were
A little grindingI checked with TBM they don't make a 155mm super pump cone. I think someone had said they modified a 144. What is involved with that?
I plan toHas anyone tried it with and without TBM cone, without changing anything else?
That looks a lot different than the 96 B2 set up without trim or the 97 B2 set up with trim.....
