Well spoke too soon. Anyone have any advice/ideas as to why the front cylinder won't fatten up?
Blaster with 61x dual 38's each has their own fuel pump and direct line to fuel tank. I'm thinking there is an air leak some place causing the front cylinder to go lean.
I have replaced about every gasket ( base, new head ada girdled, intake gaskets) I also rebuilt the carbs. The high speed on the front seems like it's not working. The back looks good plug is brown. I can run the high on the front carb all the way out with no change. Ski rips low and half throttle but once i go full it runs hard for about 1 min then dies. Like it ran out of fuel, starts back up without issue. Replaced all fuel filters, new lines.
Highs 145
Lows 72.5
Pop off 32
Factory pipe, msd enhancer, blowsion filters with outerwears .
