- Argentina
Hello, I comment. 2 years ago I used the electronic ignition of airtime and it worked well until one day, the engine did not start any more
Check stator coils and these are good. When I hit the start button, the spark starts after 2 seconds and this is very weak.
Then change the electronic ignition by the original yamaha and the engine will start. Any idea what might happen?
stator coil : 600 ohm
captor coil : 16ohm
charge coil : 1.5 ohm
ht coil : 4.5 kohm
captor coil : 16ohm
ht coil : 4.5 kohm
