Hey guys, so I am trying to figure out the best route to take for my RN in terms of the engine. Ill list all my parts, and you can tell me which parts you would use. My main question is if I should get a ported top end rebuild kit from Jetmaniac or do something with my 760 cylinder (like a Big bore?). Or do my own porting with template? Motor needs top end regardless of what I do. I just don't know all of the options that are out there. Im not trying to spend a ton of money either. Just want a nice setup with decent power that in the future I could put in an aftermarket hull for flatwater. Anyways heres a list of the parts I have... What you would do?
Carbs
Dual 44's
Dual 38's
Case
62t cases from 760 motor
Cylinders
61x cylinder
62t 760 cylinder
Flywheels
62t flywheel
61x flywheel
Electronics
62t electronics
Exhaust
Coffman sizzler
Heads
64x head
61x head
62t head
Thanks!
Carbs
Dual 44's
Dual 38's
Case
Cylinders
61x cylinder
62t 760 cylinder
Flywheels
62t flywheel
61x flywheel
Electronics
62t electronics
Exhaust
Coffman sizzler
Heads
64x head
61x head
62t head
Thanks!
