It would probably work better if you tuned the pump, then. How many mm are you from the vanes? And what other props have you tried?
Its frustrating having a ski that doesn't fit well with thw parts ya got, been there, built a superfreak before. I hear ya buddy, so tough when you have to switch gears halfway thru your vision of the build.
I haven't messed with the pump yet, I was just curious if anyone has noticed that with these pipes.
The part of the blade right off of the hub is like 1mm or less from the vanes.
Sent from my SM-G920V using Tapatalk
