- Home of the Steelers!
I have GP800 that I'd like to change the handle based trim system which lets you trim the nozzle up or down to a lever style that just trims the nozzle downward.
Problem is the two cable, handle system has two bearings in the handle which keep it in the selected position (up, down or neutral). When the two cables are disconnected from the handle the trim nozzle flops around like a drunken teenager.
Anybody know how to modify this two cable system to work with a lever style trim and allow the nozzle to remain in the neutral position unless the lever is pulled and trimming the nozzle down?
