- Milton, Florida
Can somebody post a link to a cheap but reliable compression tester that will fit an ada head? Thanks
I have tested my harbor fake cheapo compression gauge against a snap on gauge a couple times months apart and was within 1lb each other.
Cylinders never wear or fail at the same rate. A compression check is useful only for comparison. The schrader valve deteriorates over time, your cheap gauges will work like new with a fresh 99 cent valve.There is no such thing as a cheap "and" reliable compression tester. I have about 5 cheapo's in my toolbox. They are only used to compare 1 jug to the next. The actual numbers are meaningless.
Location of the schrader valve is critical too. If its way up near the gauge (usually is on cheap units), or even an inch up the line because of an adapter for your threads, then it is essentially adding to your dome volume and skewing your readings. So it would only be good for cylinder-to-cylinder comparison purposes as stated above.
I was gonna say the same thing lolThat's cold blooded! lol
