- Ahwahnee, CA
Did you send two gaskets for a reason, or just an extra one cause you're a nice guy? LOL
OEM setup takes two gaskets swished between an aluminum plate...not sure if this is used for AM reeds. But, I sent two just in case.
Yes. As far as I know, Watcon does make any, and sells the JetWorks ones for 04-up SJ carbs. The HS adjuster has same thread pattern and profile but low speed is different.
Threads are a perfect match but the point looks longer and different taper. They do thread in perfectly though and "seem" like they would work.
Are these the same ones you're used to seeing?
Interesting. I will definitely pull them out and check it out tomorrow.
As it states on our site, these are for 04-up SJ. 38mm carbs. These will NOT work in your stock 44mm OE carbs.
I am truly sorry for any confusion Corban.
What were they supposed to pop off at?Testing pop-off tonight, and it appears my needle and seats are leaking, and only popped at 18psi. So going to order a rebuild kit for each, and do a complete rebuild.
These were supposed to be on a fresh rebuild, but I guess I better be safe.
Decided to add some quick disconnect to my stator wiring. I talked to a couple people who said they did it, and I don't see any real reason not to.
