I have mine bored to 90.35mm and as you can see it's thin but working great on my KDX. Also notice the oem trim ring with built-in flow guard and a homemade SS bracket for smooth connection. With the upturn nozzle the oem ring pulls plenty of trim and offers a smooth turning, trouble free flow guard.Perfect. Thanks.
Sounds like it could be good for thrust trim. My xs has a ton of throw.
What's the biggest you could bore it?
Pulls trim easy but not as high of trim as the XS, but you don't need it with the upturn nozzle. Flow guard works well with steering mod. I'm happy with the setup.I saw this in another thread.. I like your thinking. little/no grinding. Using the stock flow guard and that XS cable holder. Does the stock flow guard work good with more throw steering set ups? also, with your home made bracket, does it pull the same as XS?
