Superjet questions
Vumad
Super Hero, with a cape!
St. Pete, FL
Stock plugs are b7hs. Most aftermarket heads run br8es. Do not run ES plugs in a stock head. It'll go very bad for you.
If you don't have any spark plug wrenches, buy a 3 pack with all 3 sizes. You only need the biggest but unless you are very limited on space then it's just a few bucks more for a set. Tons of retailers sell such things. harbor freight sells anything you need cheap but with shipping costs and whatnot id try to buy good quality tools like craftsman or maybe a professional brand.
Kuwait
The nut size is 13/16, So you'd be looking for a 13/16 spark plug socket, Amazon or eBay should work
Thank you for the information and thank you for the heads up about the ES plugs
I was told you can run es plugs on a stock head since the head is thicker and it wouldn't hit. Oh boy :/
BruceSki
Formerly Motoman25
Long Island
I've pulled apart couches with long shank plugs that have been ran like that for a long time with no issues.
If it was long enough to hit the piston, don't you think it would close the gap on the plug and shut the motor off?
