tom21
havin fun
- clearwater FL
anyone figure out how to install one of these properly? my stock one broke and I had installed one on a square I had and it was nice. Now this rn spring has no tension at all. the one end is in the hole in the pole and the other end is in the hole in the pole mount. The spring diameter is much larger than the stock and is able to twist sideways to avoid putting much tension out at all. I tried putting the spring behind the hole in the rear but can't get it back there. so I just lifted the front one for the mount out and put two larger size hoses on there to pretension the spring. I also put some hose over the pole bolt to keep the spring in place and take up the slack. It helps but I am sure that is not gonna last.
