- New Jersey
Hello,
I was ripping apart my WDK hull because of water leakage and wanted to change the scuppervalve with a one way valve after recommendations from here. I found out that the valve body was exactly the same diameter as the plastic tube and had to make a aluminum part to get the valve and tube to work together. I am curious what others do when installing this? Is the solution good enough to let the ski sit in the water for some time?
