Salt Water clean out on Fresh water boats
Bruins
R.I.P. 10/15/2011
Holland, Mi
What do most guys do to clean out there boats after riding in salt water? Is there any prep work to be done?
:haha:
I actualy flush with cooking oil:biggthumpup:
If you want to spend money on useless product, you can use salt-away. Realy its just a pain though.
Y
yamaslut
rinse the hull, motor, take the end of the hose and cram it up against the pisser and run it for 20 sec... blow it out for 10 and go drink a beer..
RoyalFlush@PCB
Shootin' The Crap
PCB
:Banane01:
I follow these procedures:
1. Back trailer into parking spot.
2. Mix a Beam and Coke.
3. Hook up hose, start ski, and flush.
4. Drink Beam and Coke.
5. Shut off water, shut off ski.
6. Mix another drink.
:biggthumpup:
Y
yamaslut
:Banane01:
:biggthumpup:
that will work too :biggrin:
Rickster
Matakana Menace
:Banane01:
:biggthumpup:
You sir can rinse my ski anytime, I will even pour!:friday:
Remember, Riders need the salt flushed out of their bodies also!:Banane01:
parrdaddy
No he will not!
How can all you guys say that Salt-Away is a waste of money? I have been using it religously since I've been riding in salt water and have yet to even have the slightest hint of corrosion anywhere! I swear by the stuff :woot: Water will not break the chemical bond that salt makes with metal alone, but salt-away will :biggthumpup:
Y
yamaslut
I have religiously not used salt away and have zero corrosion....
:smile:
hangtime
Speak up ,don't kiss azz
I have a bottle of salt away here I bought and never used .
Rinse motor ,pump,and hull than backflush through the pissers and than a coating of silicone spray which makes it harder for the salt to stick next time .I have zero rust and only go in saltwater.
