PHP (PowerHouse Products) has designed what many (including us at JetManiac) feel is the best designed intake manifold for Yamaha twin carb motors. This is a state of the art freestyle intake manifold for 62t or 64x Yamaha cases, not a manifold designed for the needs of high RPM racing. We have installed and tested them on PHP, DASA, and JetManiac/Blue motors with great results.
This intake was designed specifically for freestyle performance. It features a shorter and better designed intake track shape for more freestyle low end performance. The manifold is a 3 piece design with a removable O-ringed billet carb base plate which makes removing and reinstalling carbs easier while preserving carb linkage alignment. The manifold itself is 2 piece for future compatibilty with longer crankcases cases in development at several companies. Only a longer speed plate will be required. Removable throttle cable bracket is included.
PHP manifold is designed to work best with VForce 3 reeds and cages, but will work with stock or other reeds/cages setups. Manifold inlet is a perfect flow fit to the larger sized VF3 reed stuffers.
PowerHouse Products (PHP) billet intake mani $449.95 sale 418.95
(Includes manifold, speed plate with orings, throttle cable bracket, and all SS hardware)
