That was my thought too, get a 2 inch wide x 1/4" thick plate for underneath with tapped holes, another on top with a good weather stripping seal under the top plate and bolt it down solid. It would need some thought to be workable but in theory it should be possible. The only thing is if one were to incorporate the footholds as a removable item with the lid, it would take a fair bit of work to make it happen. I just did the big dig on my ski due to soaked foam and thought that it would be really nice to get access behind the Versi Plugs for times requiring it, or if the pump inserts needed replacing. Cutting the the tray out was not a big job but how much better would it have been if a dozen fasteners were all it needed to get in there and do the work. 10 minutes and the tunnel is open. I might still consider something to this effect.
Edit: I should mention that the plate would be a border banding type of plate, not a full sheet.
