- Windsor, Ontario
Ok guys, so I finally took the plunge and upgraded from a 95 Kawi 750 to a 96 RN Superjet 701. I ended up buying it in the spur of the moment because it presented itself as a ridiculously good deal.That being said I haven't even heard it run and I'll be honest I didn't know much about these superjets going into it.
Heres what I knew when I got it: lowered hood (I think it's all carbon), umi bars, quick steer plate, udi grips, carbon chin pad, shortened 3" handle pole, reasonably new paint and turf, battery dead and couldn't start, 62t case, 61x cylinder, speedwerx girdled head, factory limited b pipe, dual carb (assumed 38's) with primer kit choke delete, and PROK flame arrestors.
Impeller looks like new and stainless, a/m intake grate, d cut ride plate, and trim (albeit not an awesome a/m one).
I plan on gutting the engine bay and redoing everything with new hoses and hardware and complete engine gasket kit.
So after work today I got a new battery on her today and while connecting the battery cables to the battery she was sparking like crazy. Not the normal light sparking of connecting a battery, more like something was pulling some serious amperage. So I yanked the motor out. Any idea what could be causing this? Turns out I have water inside my flywheel cover
In addition, my starter is seized and the wires from the stator were cut and crimped in two separate places with different color wires which is super sketchy..
I have not had a chance to pull the ebox, I'm scared of what I might find.
On the positive side I disassembled the engine down to the crank and everything looks good, from my perspective. Looks like there's some light porting on the exhaust but they left the typical factory mismatch between the cast and sleeves on the other ports. From a quick measurement I'm getting just shy of 82mm bore maybe 81.5, I don't have a caliper on hand. See pics and let me know what you think.
I also just found out I have a 64x intake manifold that was ported, with a reed spacer, and some sort of carbon fiber reeds (see pic) fed by dual mikunis 44's.
Question: if I'm looking for an awesome freestyle setup are these 44's gonna hurt my low end torque?
Also anything else look out of place in any of the pics?
