Custom/Hybrid BRAND NEW FIXED STEER SKI COMING SOON
There will be 3 options. Large tray,low seat and a taller seat. This thing is roughly 11" shorter than an sxr. The bar height will be around 27" and can be adjustable with bar heights. The 155 pump option can be done in house and the intake opening is basically a +2 superjet. All the details will be coming soon and more pics of the ski as well.
I'm looking for a replacement for my X-2, this could be it. Might need to be shorter on rear of hull for flatwater flips
It's -4 from a sujerjet in the rear and -5 in the front. 9" shorter overall. (please dont hold me to those exact numbers but they are really close)All layups will be available and all will be vacuum infused.
I took 6" off the nose and 8" off rear of my X-2 hull, some days I think I should have only taken 4"-6" off the rear. Is it wider than a SXR on the Hull?
The hull is about 2" wider in the front area then the same towards the rear. I always liked the way my gen 2 was able to slide if you wanted but could also be leaned over and would carve a hard turn. It seems most flat water people like the ski to be able to slide. This ski was designed as a freeride ski but should be a capable flat water ski as well. Similar in length to a -4 super freak. It will fit a full size gas tank with a b pipe setup or similar. Also can be fueled from the outside. The steering stems will be provided by me as well. They will be specific to this hull.
