Super Jet i need a silent pipe HELP
i need a silent pipe , I ride on a small lake (2.5mi) and I cant piss all the neighbours off with the noise. We ride like 3 hours a day , I want a Bpipe so bad but I cant :Eyecrazy:so if there is no silent pipe available what mod can I get away with I have a 2007 sj
Byeai
"Cheetos-Man"
Melbourne FL
Impeller and head but to make it breathe better u need a pioe but u can use ur stock water box and add a water line straight into it and it will quiet it down
B pipe with stock water box isnt to loud
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
tor*p*do
Squarenose FTW
NW NC
I switched my b pipe from a Mod chamber to the C-4 chamber
and it quieted it down a lot
No where near as pingy and less annoying
Ohio
You would simply make one. Drill and tap your waterbox...and insert a brass elbow just like we use off the heads or for dual cooloing B pipe manifolds.
I did this to a 760 with a TDR waterbox and it sounds awesome! Quiet enough IMO.
Ohio
I should add we ran dual flow control vavles on the dual cooled TDR waterbox/760. So it was dry and then silenced as you got on it! It sounds cool!
I still need help with this
I want a b pipe but I has t be as silent as stock
hanks guys
What you want doesn't exist. Sell the ski and buy a Hydrospace 4-Stroke if you can afford it. Or buy an SXR 4-Stroke conversion. Or do one yourself.
