Footholds! Thanks WCF!
Dirtybird
Ex*ta*ski
St. Clair, MI
Fast shipping with Christmas and all, talked to Steve on the phone, great guy! He shipped them out that day and they are here already, a set for my SXi and a set for the SJ. :woot:
Rickster
Matakana Menace
Wow...
1 - footholds, check
2 - dremel, check
3 - 5200, check
4 - rivets, check
5- Foam in a can, check
6 - fiberglass, check
Don't forget the cold beer
Here is the pic you wanted...
tor*p*do
Squarenose FTW
NW NC
Hi Rickster-
My REVs showed up today and I start cutting tonight.
Couple of questions:
Why use 5200 when you will be mixing and playing with resin anyways? I plan to just use a small mix of the epoxy resin.
Why can foam and not 2-part foam? All the threads are down on "great stuff" and other spray cans of foam.
By fiberglass, I assume you mean ribbons or cloth fiberglass to be wetted down with epoxy, 2-part resin. You dont mean fiberglass like bondo or cheap polyester resin, do you?
Thanks, I am starting my first foothold install and I want to make sure I do it right!
Rickster
Matakana Menace
Why use 5200 when you will be mixing and playing with resin anyways? I plan to just use a small mix of the epoxy resin. Epoxy resin will be fine.
Why can foam and not 2-part foam? All the threads are down on "great stuff" and other spray cans of foam. I used great stuff becasue the hull I just installed holds in had never been in the water (and was completely sealed prior to going in the water) so there should not be any water absorbsion problems. If you are foaming the ski, then I would use two part, but if you are only doing the footholds, then great stuff should be sufficient.
By fiberglass, I assume you mean ribbons or cloth fiberglass to be wetted down with epoxy, 2-part resin. You dont mean fiberglass like bondo or cheap polyester resin, do you? fiberglass mat is what I used.
Thanks, I am starting my first foothold install and I want to make sure I do it right! Have fun and make sure the beer is cold.:Banane01:
Y
yamaslut
Hi Rickster-
don't use polyester on smc or metton unless it specifilcy says it's made for it... It won't stick.
Just use a mix of cloth and matte w/ a two part epoxy for the resin
P
PancakePete
Wait till you get them padded up and Ready to Rip....
I love my WCF holds... They make Happy Feet ! :Banane01: :purr:
WaveDemon
Not Dead - Notable Member
Hell, Florida
I don't know what ski he's working on but I"m pretty sure the top deck is fiberglass on a roundie.
Y
yamaslut
best to grind both surfaces where applying the glass and 5200 would help the seal and couldnt hurt the strength
yup... use the roughest sand paper ya got... I use 36 grit and tear it up.. make sure you sand the turf and padding w/ 80 grit... that helps it stick good
DR3
Xscream Braaaap
palm harbor, Fl
yea 36 on a grinder would be easiest but if you have to do it by hand you can get a good shoulder workout:woot:
Y
yamaslut
either way works... be carful if ya use 36 grit on a grinding wheel... you will eat up lots of material quick
B-Roy
Makin' a Comeback!
MICHIGAN
I just finshed mine tonight. Came out real good.
I 5200'd than rivited them.
Than I glassed them in using 1208 Biaxial, and west systems.
And foamed them using the 3# density.
waterfreak
I had a vision!
s florida
you're very welcomed!:biggthumpup: Seems that there are numerous different ways about installing footholds. All seems to work fine, just take your time and make sure you re-inforce the bottom deck :biggthumpup:
