I'm sure you could just cut the barbs off a billet one, drill it out to the correct size and tap it to accept a 90 deg brass fitting.
It's a slow day at work, I'll whip something up in solidworksYeah that is an idea too! My question there is how much would the 3/8 line be further restricted by inserting the brass fitting inside the line. Might be ok if it was a 1/2 pisser I guess.
I was thinking more along the lines of a 2 part pisser, where the barb is removed, and it screws into a female thread on the 90 degree elbow that also keeps it tight against the hull. nice, low profile, it would make me happy!. I will take a look at what you have mentioned here too! Thanks for the feedback all.
I told you to do OCD's idea last night and you whined that you want to use 1/4 NPT for your 1/2 inch lines!
I still think that is your best option though. Ever since I took all my 3/8", 1/8 NPT brass fittings and drilled them out as far as I could, I've never had a problem getting enough water to cool the engine...
Awesome!It's a slow day at work, I'll whip something up in solidworks
8mmYes, nice work and pretty much what I had in mind! Whats the ID of the pisser going to be?
