Hi, this is gunna be a big post so ill say sorry now and hipe yous take the time to read it n try help me. im new to the forum i recently bought a 701 single carb. First ride it was running on 1 cylinder. Pulled apart ebox had a bit of water in it. Sprayed Wd40 in all connections. Siliconed up real well. Started n ran on 2 cylinders.
Took it back out to the water. Rode for an hour then went back to the same problem..was gettin poopty spark. Turned out i needed spark boots. Bought some new ngk ones and it is now getting great spark.
Took it back out in the bay today was riding on and off for about 3 hours out there. And the battery died. Had the bilge running constantly so thought maybe it was that...
Jumped it off another battery.
Took it out riding for about 2 minutes and the whole thing shut off as if u pulled the safety key.
Had to swim back to shore. Swapped batterys. Cranked over took it out for 3 minutes n again just stopped. Started swimming i back in. While trying to crank it and get it started n it started again. Got back to shore. Checked spark. All good. Took it out again. And again died. Swam a bit started but then died again.
Someone please help!? Have no idea the problem. Feel as if i bought a dud!
