D-Roc
I forgot!
- Dirty River Rider
its all about power to weight ratio, sometimes it is easier/cheaper to loose weight than make hp, i stripped everything that wasn't needed on my ski to better the ratio, once my ski is ready for next spring i will dry weigh it to see how i am, i reinforced quite heavily but used about 1/2 dow foam to fill in the hull when i refoamed so i used alot less 4lb foam to fill it. Dow foam will not absorb water at the same rate either, i used a RN exhaust tube to make circle dow plugs to fill in the void when i removed the stainless rear exhaust tube. i had to pound them in from both ends and then sealed it up, when steve did his ski (the camo) he only had to use one coffee cup of 2 part for each side of his ski to have it flow out, been holdin up real well for two seasons.
