Want to add Ada Non Girdled Head and Zero Flywheel, is 91 safe?
Wisconsin
I currently have one mod done to my stock engine, the temp sensor jump. That puts my SXR at a 6 degree advance.
I want to keep my boat running 91 octane (available all over Wisconsin) and not have to do any carb tweaks to boot!
So will adding a non girdled Ada head rated at 180psi/91 octane and Zero Flywheel(drilled) be totally safe on 91 gas?
I'm going non girdled because I don't plan on pusihng the psi past 180-190. I plan on riding some Lake Michigan surf and making a trip to Daytona this Jan, so let me know if you would always go "girdled".
thanks dudes!
Wisconsin
I would say no. I'm pretty conscious about that. I tend to just slalom and chase waves. When I go long distances I try to stay in the mid-range to conserve fuel.
stagesrt4
see ya out there
St Charles IL
id shoot for 175 psi domes with your setup n how you ride
lightened flyweel doesnt change anything... just makes the rotational mass lighter....
my X2 with 190psi runs 93 octane with Zero detonation(but i blip a lot)
Wisconsin
Ada states the 32cc domes are 180psi, so I can't really get 175 can I? I can also remove the jumper and go back to stock timing. I only noticed a sharper hit in the mid range with it anyway.
do not bump compression AND do the timing jump without increasing octane. it is basically 1 or the other to stay absolutely safe on pump gas...185 psi and the temp sensor bypass on 91 octane is asking for trouble
stagesrt4
see ya out there
St Charles IL
thats a rough number
depends on current compression n what gauge
can always change thickness of base/head gaskets to achieve desired #
Wisconsin
I will check the compression once I get the head installed, and most likely re-connect the sensor. I currently have about 156+ compression at 870ft elevation on my cheapo Comp gauge, both cylinders are dead even.
stagesrt4 I get paid tomorrow
stagesrt4
see ya out there
St Charles IL
Save money, make your own ignition advance jumper using a 3M UR connector.
It works well and is waterproof.
You can get them at Lowes or Home Depot!
Your air temp sensor:
Cut the wires even and near the middle
(so you can reverse this procedure if you want to)
Insert the conductor ends from the plug end completely into the UR connector until they bottom out.
Crimp down firmly with some pliers until the dialectric grease squeezes out and the red button is flush
You are done, plug it back into your ski, VOILA! 6 degree advance.
Its true about the stock skis winning. Its about the rider. Practice, Practice, Practice. You can beat faster skis being a better rider!!!
subhard
TITS OR GTFO
anchorage ak
Like these guys are saying you can bump compression and do the jump but it WILL seize your motor if held wfo for extended periods of time. Even on 91 octane fuel. Ask me how I know. This is because the jump is not a static advance. It turns into a 23 degree advance when wide open. So if you're only interested in low end then do both and just be careful.
Wisconsin
Can't I just solder the two wires together with some shrink wrap to advance the timing?
I thought the same, but the wire must be stainless or some other non-corrosive metal. I could not get solder to stick, went with a waterproof automotive crimp.
I found a place in town that carries 94 octane, so I'll probably start going there. Just a little farther drive.
