Hello,
I have my ski now for a couple of months and lately it's been burning a set of plugs by the end of each day I ride.
This is everything I have done to the ski up till now. basically resolving issues.
-I removed a restrictor from inside one of the water lines which was causing the engine to overheat since I live in warm weather.
-I tapped the manifold to switch to dual cooling, and I am running the "true dual cooling" waterline setup
-I also tuned my b-pipe to mid+bottom closed, and top at 3/4.. This made a huge difference in low-mid end snappyness. Not sure if this can have anything to do with burning my plugs.
-My carbs are set to: low=1 1/4 about and top end is at 1 1/2
-Burnt a ground wire going to the stator because my started was bad. The magnets inside were stuck and corroded and was constantly pulling electricity (has new starter now)
Another thing that has been happening a lot is each time i do a 180 slide or 180 areal the engine kind of bogs pretty bad and i have to idle and play with the throttle until it clears up. This also happens basically each time i start it up in the water. With fresh plugs it happens les (pretty sure)
you can see what I mean at @2 minutes in this video
I want to go in the surf but as long as it's bogging and burning plugs I don't think it's a good idea
If anyone can help me out would be great. Thanks!
