- McHENRY IL
	That's where I put mine edit put mine on the side my badHere is another from one of my other 62T motors. Had to JB Weld it
That case has been that way for 6 years with no issues.I'd just swap cases rather then risk jb weld taking out a cylinder
Even still. If you can get full threads I'd do it. Why not just run a "T" fitting in your pulse line to each carbThat case has been that way for 6 years with no issues.
Mine was this way when I purchased the ski so I just left it. My first set of cases posted were 62T cases from a 760 motor so they came that way. I've never tried a T fitting so I'm not sure from personal experience how that would work, but I'm sure others have tried it.Even still. If you can get full threads I'd do it. Why not just run a "T" fitting in your pulse line to each carb
Swap cases did they ever come from factory with dual pulse fittings. Besides that there just pressed in
