Y
yamaslut
wow... the irony of it all
you mean surfrider gets free parts from WCF? that explains a lot. :bigeyes:Can we have pics of the famous 'SFL Garbage Can' please!:Banane01: :Banane01: :Banane01:
every shop needs a pitbull?
would that make charlie watercraftfactorydawg:dunno:
I wish all hull manufacturers would post pictures of their hulls in different stages of the build process.
I would love to see their top of the line hulls as well as the less expensive units built for those who might be more financially challenged.
That way we could compare what each manufacturer is doing, what materials are being used and what you get for your $$$.
Apples to apples.:cool2:
Do you still have to glass over watercraft factory footholds to prevent them from cracking? Previously, I heard multiple accounts where they've been too thin.
true, and from what I understand a bottom deck conversion is legal in amatuer freestyle.I would like to know the weight of an OEM bottom deck vrs. an aftermarket bottom. We all know the top deck is not where the weight is, so why not a bottom deck conversion if the weights are worthy of the $ & work? This could be a cheaper way to a light hull?????
sweet, where do I sign up to get a square top with a bottom conversion?I know squarenose bottoms can weigh like 56lbs :bigeyes: So in all honesty a conversion ski is kind of pissing in the wind. The bottom deck is what is so heavy. Aftermarket bottoms typically weigh about 30-35lbs
The foam is what gives the footholds their strength, not the material the footholds is made of.
no, they're SMCThe OEM bottom hulls are just chopped glass right? Aka: chopper gun?
no, they're SMC
sheet molded compound. not that I know what that means.
