deftons56
Brian
- lake goodwin
You're not checking stuff correctly.
Sent from my SCH-I545 using Tapatalk 2
yessirHave you removed the prop?
ur a dumbass.
seriously? Lol dudeYou're*
Helping you is kinda like helping out a porcupine. You come across like a little know it all prick who clearly believes he is smarter than everyone else here.You ask for help but then spew poop back on why our advise sucks and how you already tried everything already. Would you continue to give advise to someone who acted this way? If you read back, all the advise was civil and on point until you started getting snippy with people.
dude get a licoriceing life^ I looked it up that is a real word that's awesome.
@kwakhead you should take it to high school with you next year. All the girls will start it up in the parking lot. You won't be known as (crack head). You will be the guy with the first gas powered vibrator I found the silver lining for you!
lol thanks for the suggestion. I'll give it a shot for the literally 8th time I've taken out the pump and impeller assy. Who cares! Let's give it another swirView attachment 251876
Try removing the pump unit. If i remember correctly they bolt up right up to the back... then check your bearings and impeller.. all will be visible to see once its out of the ski. if you have a impeller removal tool.. insert it into the prop nose and spin with with a elec drill with a matcing socket or similar... Then with your hands and clothes out of the way....<< this is optional... check for abnormal binding or noises that you may not hear while the engine is running....
Other than that.......ride in deeper water...this will alleviate alot of your moms vibration issues
Only if you wiggle your toesGet a life stay off my thread screw being civil I'd like to shove my foot up ur ass
I'm done with this.Only if you wiggle your toes
