speedysprocket
Alex
- Chesapeake, VA
You sure the engine is healthy and that's not what's busted and causing the vibration?
positive. Checked all motor mounts as well. And somebody mentioned water migration problem or something? It has a hardcore vibration in and out of water.You sure the engine is healthy and that's not what's busted and causing the vibration?
I had no idea wtf water migration isbased on the fact you even remotely considered his post leads to the conclusion of you needing to remove yourself from the jetski scene.
What does it do when you run it without the driveshaft in?
no. I tried running without the shaft in. The engine does not put out the vibration I'm referring to.This is a pertinent question for the OP. Sine you were experiencing vibration in and out of the water, does removal of the driveshaft solve this?
that's how tigershark designed the POS lol. Like I said I don't ride vibrating coucheswell if it f**king wiggles by hand how it is supposed to NOT wiggle and vibrate like a motherfu*cka at 6000+ rpms.
good suggestion......^ Then go to the couch forum .
this is correct. They require no skill as well.But your mother does!![]()
I got it lol I just went with it
