jeremy chambon
Need more power
- rockford MI
Motor good and shimmed properly all the pump bearings are good. You said the shaft is running true and the splines are good. Motor mounts are good. Every pointer that has been given to you has check out good. Does the impler have any damage? Bent blade missing edge? If everything is checking out good your not checking it right since every base has been covered. From my experience shafts just don't wear out 99% of the time there is typicly something causing them to prematurely fail.
