Wow, nice pics
@VXSXH20 .
Thanks
@Joker. So say I wanted to do something like splash my ride plate so I can try a d cut, am I better off using an epoxy based layup to make the mold and the part? Price point is the issue...sorry for getting a bit off topic op.
Prep the ride plate by detailing it. Any imperfections in the plate will show in the mold and the part.
Build a flange for the mould around the part. You can use foam and filler, clay, playing cards and packing tape, whatever works.
Wax the plug buffing between coats.
Use a mold skin like Pva here if you like.
Coat the mold. Gelcoat is best, preferably sprayed but can be brushed. And alternative is to heat some resin up befor you mix the resin, which will prevent air bubbles. Mix resin, paint a layer on the mold, allow to dry to tacky but not cured. This will do the job gelcoat does but expect some pinholes. Gelcoat is hard to brush on without allegatoring.
Fill any sharp angles with resin mixed with a filler to avoid air pockets.
Layup your glass, usually twice as thick as you plan to make the part, but not more than 1/4" at a time to prevent heat warp.
You could use epoxy, but ISO resin has minimal shrinking and is much easier to work.
Layup a 1-3 layers of chop, then cover it with a layer I conform cloth, then roll it. Repeat as necessary.
Epoxy will not desolve the starches in chop, thus it is hard to penetrate, so I wouldn't use chop of you plan to use epoxy.
