Super Jet Running issue
Yami-Rider
TigerCraft FV-PRO
Texoma
Update: It was a faulty stator.
Been working on a 94 SN and I can't seem to get it running right. It has never ran just right since my buddy bought it, he knew about the issue, but thought it was a carb problem, seems to be more than that.
Setup
61X/61X
Factory B-pipe
Hooker 9/15
MSD Enhancer
600 Feet above sea level
SBN 44
125 pilot
155 main
1.5 N&S
22 PSI Pop-off
1.25 turns out on high
1/8 to 1 turn out on low speed (Doesn't seem to change how it runs once its running bad)
When you first start up the ski when its cold it hits surprisingly hard right off bottom, then after you ride it for about 5 min you lose that low end snap.
You can be going under 1/4 throttle, then give it full throttle and the rpm's only raise to about 2500 RPM (guesstimate) for 1 to 3 second then like a light switch it just takes off to full RPM, engine doesn't cut out, just seems like my throttle cable take 1-3 seconds to catch up to my finger, but i know that's impossible.. No matter how much you ride it, it always seems to run great on top end, once you get there.
First run after he bought it, I noticed the b-pipe was over 200F, so i backed the top and bottom screws out. It cooled it down a little, but it is still hotter than my B-pipe on my 98 SJ, I have backed the screws out 5+ turns, its still hotter than my 98 SJ, but under 200F now. I also noticed that the water adjustment screws are just normal SS 5mm bolts, instead of a needle adjuster. Could the pipe running a little too hot and not enough water cause this running issue?
When he bought the ski the throttle shaft had so much play in it, that it leaked fuel around the shaft, it was also leaking fuel from the fuel pump, so we put a new carburetor on, but still have the same issue running issue.
I took out the MSD enhancer and tried a known good CDI, still same issue.
Also tried new spark plugs, they are coco brown.
Maybe a heat break down issue in the coil or coil wires?
Any help would be really appreciated!
Stockton
Your b-pipe head pipe sounds suspect, "dry pipe lag" it reminds me of. like Quinc suggested make sure you have proper flow to the pipe. I'd also suggest pulling the head pipe and hooking the water line to a garden hose, cap the other off and check flow and spray patterns of your adjusters see if any issues with those odd bolts.
Their is a thread on doing this I think it starts page 2
http://www.x-h2o.com/index.php?thre...-for-best-spray-patterns.133660/#post-1471679
Yami-Rider
TigerCraft FV-PRO
Texoma
Make sure your cooling lines are not clogged or have any holes in them.
I back flushed the ski last night, but haven't tested it again yet. Will check lines when i have the head pipe off.
Thanks for the info! I will try that.
whats the cylinder compression #?
I normally start there first, but i rebuilt the engine last year when my brother still owned it, so i assumed it is good. I will check it.
Is the FCV dumping to much water into the waterbox?
Dont have a FCV on my SN. Im running a 2.0 carb. seat in the line to restrict water flow. Ran that setup on my RN for years before i bought a FCV with no issues. It always takes about 5 minutes before the issues occurs.
