Blaster was running like crap. Had no power. So I decided to check the compression. Tested at front 150 rear 120. Took the head off and this is what I found.
It looks like the only damage was to the side/top of the rear piston and the dome. The oring came off when I removed the head.
The cylinder sleeve still feels smooth and doesn't have any bad marks like the piston. The crank still feels good with no slack and the bearings are still holding good. Could something have made its way in there some how and caused this damage? The only metal shavings I could locate were on the dome which I am guessing came from the piston. Lol
Sent from my SAMSUNG-SGH-I337 using Tapatalk
