JetManiac's Electrical Parts Shop
Find almost any electrical part to build or repair your ski right here. High quality new, used, and rebuilt OEM yamaha parts. Buy with confidence, JM parts are professionally inspected and selected, and even used parts are covered by JetManiac's satisfaction exchange warranty.
Electrical Box (Ebox) parts
Ebox gasket -new OEM Yamaha 25.95
Ebox gasket -new a/m Yamaha 17.95
Ebox rear -OEM aluminum, nice clean freshwater 49.80
Ebox front cover -OEM, clean used 29.
(Bgrade, scratches 20.)
Ebox fuse cover cap -new OEM Yamaha 15.99
Ebox fuse cover cap gasket -new OEM Yamaha 13.99
Ebox fuse cover cap with gasket -OEM, used 8.95
Ebox fuse holder assembly- OEM clean, used, tested 15.90
Ebox head temp sensor to ebox -OEM, clean used 24.90
Ebox blank rubber grommet 6.90
(to replace temp sensor or any other spot)
Ebox screws
- New Yamaha OEM stainless 2.95/ea
- New Yamaha a/m stainless 1.59/ea
- clean used OEM 1.35/ea
Ebox internal bolt kit (8 OEM clean bolts) 9.90
Ebox to hull SJ mounting bracket -new OEM Yamaha 26.85
(fits 1990-2020 SuperJets)
SS ebox bracket mounting hardware kit to ebox and to hull for 2 brackets 6.90
Bling washer for Ebox bracket to hull (for M6 tapered head bolt) 2.95
Ebox rear direct to ebox back mount M8 bling washers 3.49/ea
Ebox Start/Stop switch SJ OEM ebox side harness -new $96.99 sale 87.85
Replacement OEM Start/Stop connectors 13.95/set
(1 Male and 1 female connector housing for switch side and for ebox side, 4 crimp on connectors, and 4 rubber seals)
*2 sets needed to replace all connectors on switch and ebox. Good for TL setups as well.
CDI units
CDI unit (6m6, 61x, or 62t) -OEM Yamaha, clean, used 145.80
(30 day exchange warranty)
MSD enhancer for Yamaha $487. sale 434.95
ZEEL Zeeltronics
62t
Zeeltronics 62t 701 programmable CDI $439.80
(Comes preprogrammed with the WAX curve, we recommend verifying your initial timing before use.)
760
Zeeltronics 760 -A02T HRS 4pin programmable CDI $409.80 (newest model)
(Plugs directly into Yamaha 760 Stator, Comes programmed with the WAX curve)
Zeeltronics PC-USB HRS programming/chip conversion computer hookup cable for new 760 Zeel and for 62t CDI unit 65.95
Zeeltronics 760 -A02T 10pin programmable CDI $395.80
- Can be programmed for use on Kawi 750/800
Zeeltronics 10pin 50cm extension cable for 760 CDI unit 11.95
(plugs into Zeel CDI and extends programming plug to ebox fuse cover cap)
Zeeltronics 760/10 pin PC-USB programming/chip conversion computer hookup cable 64.95
Zeel Blank new 760 stator grommet to cases/flycover 12.95
Zeeltronics PC-USB HRS programming/chip conversion computer hookup cable for 62t CDI unit 65.95
Starter solenoid/relay -New OEM Yamaha $127.99 sale 107.89
SuperJet '02-20 square relay with attached rubber mount, 2 shorty bolts to cables
or
Starter solenoid/relay -New OEM Yamaha $101.99 sale 79.98
90–01 round relay snaps into rubber ebox holder, with studs and nuts to cables
Starter solenoid/relay -New a/m for Yamaha 39.95
(1 year warranty)
Starter solenoid/relay -OEM clean, used, tested 39.95
Voltage regulator/rectifier OEM Yamaha -New $111.99 sale 99.88
Voltage regulator/rectifier OEM -clean, used 27.90
(90 day exchange warranty)
Battery /Ground cables
OCD Solutions Surf Armor Battery Cable kit 85.90
HD marine grade custom made power cables.
(ebox to battery, ebox to starter power cables and ground cable.
New OCD ebox to battery(+) Red SJ length power cable 31.95
New OCD ebox to starter(+) Red SJ length power cable 29.95
New OCD ground cable(-) battery to starter Black SJ length 29.95
New OEM ebox to battery(+) Red power cable $65.99 sale 59.95
New OEM ebox to starter(+) Red power cable $92.99 sale 85.99
New OEM ground cable(-) battery to starter Black SJ length $103.99 sale 95.80
Ground cable starter end rubber boot -Yamaha OEM used $8.95
Starter cable starter end rubber boot -Yamaha OEM used $8.95
Battery/Ground cable end rubber boot -Yamaha OEM used $8.95
OEM style ebox and stator connectors
(also good for total loss wiring)
5 M/F Terminal set 9.95
(5 male terminals and silicone boots, 5 female terminals and silicone boots)
10 M/F Terminal set 16.95
(10 male terminals and 10 silicone boots, 10 female terminals and 10 silicone boots)
Ignition Coils
JetManiac Yamasaki all NEW OEM ignition coil 187.
New OEM Kawasaki ignition coil (hotter spark, lower price) with NEW Japanese OEM wires and black, red, bright yellow, blue, green, neon green, pink, purple, white, or orange sheathing and NEW Yamaha OEM ebox grommets and MSD boots/terminals installed and surf sealed
This is the ultimate coil for any ski, but especially for surf and high performance use.
*fits Yamaha '90-20 SuperJet and '93-96 WaveBlaster 701
OCD Solutions OEM rebuilt coil 139.80 (out of stock, backorder)
OEM coil -reconditioned, cleaned and tested with new wires, MSD boots, and terminals installed.
OEM Yamaha ignition coil -clean, used 69.80
MSD spark plug boots
MSD spark plug boots and crimp-on terminals kit 13.95
(kit includes 2 HD silicone boots and 2 terminals)
MSD crimp tool 16.95
MSD replacement crimp-on terminals 3.95/ea
or 6pk for 18.90
Triple MSD spark plug boots and crimp-on terminals kit 20.95
(kit includes 3 of each)
MSD Red boot retainer 14.95
MSD battery quick disconnect kit $36. sale 25.70
NGK Spark Plugs
BR8HS solid tip -standard length for stock Yamaha size
BR8ES solid tip -longer reach for Yamaha with a/m head or all Kawasaki
MSD Total Loss parts
MSD TL ignition coil
MSD TL pickup
Custom TL plug wire sets
Custom TL power and ground cables
SeaDoo OEM total loss relay (with plug in wiring harness) 49.95
Bilge pumps and bilge electrical parts here:
Link: New - 'Water Out' Shop -Bilge Pump, Scupper, Versiplugs, Hood seals, Billet outlets, hose, mounts, etc.
Ebox screws
CDI units
ZEEL Zeeltronics
62t
760
or
(1 year warranty)
Ignition Coils
or 6pk for 18.90
NGK Spark Plugs
MSD TL pickup
