JM Electrical Parts -Ebox,Starter,Bendix,Flywheel,Stator,Start/Stop,Solenoid,CDI, MSD
JetManiac
Stoked
orlando
JetManiac's Electrical Parts Shop
Find almost any electrical part to build or repair your ski right here. High quality new, used, and rebuilt OEM yamaha parts. Buy with confidence, JM parts are professionally inspected and selected, and even used parts are covered by JetManiac's satisfaction exchange warranty.
Electrical Box (Ebox) parts
Ebox gasket -new OEM Yamaha 25.95
Ebox gasket -new a/m Yamaha 17.95
Ebox rear -OEM aluminum, nice clean freshwater 49.80
Ebox front cover -OEM, clean used 29.
(Bgrade, scratches 20.)
Ebox fuse cover cap -new OEM Yamaha 15.99
Ebox fuse cover cap gasket -new OEM Yamaha 13.99
Ebox fuse cover cap with gasket -OEM, used 8.95
Ebox fuse holder assembly- OEM clean, used, tested 15.90
Ebox head temp sensor to ebox -OEM, clean used 24.90
Ebox blank rubber grommet 6.90
(to replace temp sensor or any other spot)
Ebox screws
- New Yamaha OEM stainless 2.95/ea
- New Yamaha a/m stainless 1.59/ea
- clean used OEM 1.35/ea
Ebox internal bolt kit (8 OEM clean bolts) 9.90
Ebox to hull SJ mounting bracket -new OEM Yamaha 26.85
(fits 1990-2020 SuperJets)
SS ebox bracket mounting hardware kit to ebox and to hull for 2 brackets 6.90
Bling washer for Ebox bracket to hull (for M6 tapered head bolt) 2.95
Ebox rear direct to ebox back mount M8 bling washers 3.49/ea
Ebox Start/Stop switch SJ OEM ebox side harness -new $96.99 sale 87.85
Replacement OEM Start/Stop connectors 13.95/set
(1 Male and 1 female connector housing for switch side and for ebox side, 4 crimp on connectors, and 4 rubber seals)
*2 sets needed to replace all connectors on switch and ebox. Good for TL setups as well.
CDI units
CDI unit (6m6, 61x, or 62t) -OEM Yamaha, clean, used 145.80
(30 day exchange warranty)
MSD enhancer for Yamaha $487. sale 434.95
ZEEL Zeeltronics
62t
Zeeltronics 62t 701 programmable CDI $439.80
(Comes preprogrammed with the WAX curve, we recommend verifying your initial timing before use.)
760
Zeeltronics 760 -A02T HRS 4pin programmable CDI $409.80 (newest model)
(Plugs directly into Yamaha 760 Stator, Comes programmed with the WAX curve)
Zeeltronics PC-USB HRS programming/chip conversion computer hookup cable for new 760 Zeel and for 62t CDI unit 65.95
Zeeltronics 760 -A02T 10pin programmable CDI $395.80
- Can be programmed for use on Kawi 750/800
Zeeltronics 10pin 50cm extension cable for 760 CDI unit 11.95
(plugs into Zeel CDI and extends programming plug to ebox fuse cover cap)
Zeeltronics 760/10 pin PC-USB programming/chip conversion computer hookup cable 64.95
Zeel Blank new 760 stator grommet to cases/flycover 12.95
Zeeltronics PC-USB HRS programming/chip conversion computer hookup cable for 62t CDI unit 65.95
Starter solenoid/relay -New OEM Yamaha $127.99 sale 107.89
SuperJet '02-20 square relay with attached rubber mount, 2 shorty bolts to cables
or
Starter solenoid/relay -New OEM Yamaha $101.99 sale 79.98
90–01 round relay snaps into rubber ebox holder, with studs and nuts to cables
Starter solenoid/relay -New a/m for Yamaha 39.95
(1 year warranty)
Starter solenoid/relay -OEM clean, used, tested 39.95
Voltage regulator/rectifier OEM Yamaha -New $111.99 sale 99.88
Voltage regulator/rectifier OEM -clean, used 27.90
(90 day exchange warranty)
Battery /Ground cables
OCD Solutions Surf Armor Battery Cable kit 85.90
HD marine grade custom made power cables.
(ebox to battery, ebox to starter power cables and ground cable.
New OCD ebox to battery(+) Red SJ length power cable 31.95
New OCD ebox to starter(+) Red SJ length power cable 29.95
New OCD ground cable(-) battery to starter Black SJ length 29.95
New OEM ebox to battery(+) Red power cable $65.99 sale 59.95
New OEM ebox to starter(+) Red power cable $92.99 sale 85.99
New OEM ground cable(-) battery to starter Black SJ length $103.99 sale 95.80
Ground cable starter end rubber boot -Yamaha OEM used $8.95
Starter cable starter end rubber boot -Yamaha OEM used $8.95
Battery/Ground cable end rubber boot -Yamaha OEM used $8.95
OEM style ebox and stator connectors
(also good for total loss wiring)
5 M/F Terminal set 9.95
(5 male terminals and silicone boots, 5 female terminals and silicone boots)
10 M/F Terminal set 16.95
(10 male terminals and 10 silicone boots, 10 female terminals and 10 silicone boots)
Ignition Coils
index.php
JetManiac Yamasaki all NEW OEM ignition coil 187.
New OEM Kawasaki ignition coil (hotter spark, lower price) with NEW Japanese OEM wires and black, red, bright yellow, blue, green, neon green, pink, purple, white, or orange sheathing and NEW Yamaha OEM ebox grommets and MSD boots/terminals installed and surf sealed
This is the ultimate coil for any ski, but especially for surf and high performance use.
*fits Yamaha '90-20 SuperJet and '93-96 WaveBlaster 701
OCD Solutions OEM rebuilt coil 139.80 (out of stock, backorder)
OEM coil -reconditioned, cleaned and tested with new wires, MSD boots, and terminals installed.
OEM Yamaha ignition coil -clean, used 69.80
MSD spark plug boots
MSD spark plug boots and crimp-on terminals kit 13.95
(kit includes 2 HD silicone boots and 2 terminals)
MSD crimp tool 16.95
MSD replacement crimp-on terminals 3.95/ea
or 6pk for 18.90
Triple MSD spark plug boots and crimp-on terminals kit 20.95
(kit includes 3 of each)
MSD Red boot retainer 14.95
MSD battery quick disconnect kit $36. sale 25.70
NGK Spark Plugs
BR8HS solid tip -standard length for stock Yamaha size
BR8ES solid tip -longer reach for Yamaha with a/m head or all Kawasaki
MSD Total Loss parts
MSD TL ignition coil
MSD TL pickup
Custom TL plug wire sets
Custom TL power and ground cables
SeaDoo OEM total loss relay (with plug in wiring harness) 49.95
Bilge pumps and bilge electrical parts here:
Link: New - 'Water Out' Shop -Bilge Pump, Scupper, Versiplugs, Hood seals, Billet outlets, hose, mounts, etc.
JetManiac
Stoked
orlando
OEM Stators and Lightened Flywheels
61x
61x OEM JM recon. stator 194.75
(Clean used, coils tested, fixed as needed, 90 day exchange warranty)
61x OEM lightened flywheel 159.
(Approx. 1/2 lb. of rotating mass removed)
62t
62t OEM lightened flywheel 195.
62t OEM JM refurb stator 298.
(Clean oem used, tested, fixed as needed, 90 day exchange warranty)
New 62t OEM stator $792.99 discount to 678.60
New 62t OEM stator replacement charge coil $252.99 sale 199.80
New 62t a/m stator $118.
Jetinetics 62t billet lightweight flywheel $795. sale *contact for current sale price
760/64x OEM stator/flywheel cover/harness assembly 219.
(4 months exchange warranty)
PUSH billet Yamaha flywheel lock tool 49.95
Cold Fusion billet Yamaha flywheel lock tool (not available, possibly discontinued)
Flywheel puller tool 29.95
New Flywheel cover gasket 12.95
JM allen head flywheel cover stainless bling bolt/washer kit $11.95
Woodruff key for flywheel OEM Yamaha 12.49
Flywheel bolt OEM Yamaha SJ -New $36.99 sale 32.89
(no oil pump drive ears)
Flywheel bolt OEM Yamaha SJ -clean, used 12.90
Blank new stator grommet to cases/flycover 11.95
(for Zeeltronic or MSD TL install)
Threebond 1211 High Temp, Hi quality silicone sealer 23.95
(great for both flywheel cover gasket and for starter nose as well as between crankcase halves.)
Under the flywheel cover hardware kit 39.80
(OEM Yamaha flywheel bolt, 2 stator bolts, flywheel woodruff key, bendix front cover spring and 2 washers- all OEM clean, used, inspected parts)
Maniac SS Allen flywheel cover bolt kit $13. sale 10.90
(7 SS bolts with SS washers)
Yamaha 650/701/760 Oil pump blockoff kit 13.
Yamaha 800/1100/1200 Oil pump blockoff kit 13.
Starters
index.php
Aftermarket starters don't last and aren't as powerful as OEM Mitsuba starters. But new OEM starters are really expensive from Yamaha so JetManiac is rebuilding clean oem starters to fill the gap between new oem and a/m starters. They are totally disassembled, cleaned and rebuilt as necessary and finished with multiple coats of black satin epoxy paint.
Yamaha 650/701/760 Starters
New OEM Yamaha starter $567. sale 448.
New ProTorque GOLD 701/760 starter $229. sale 169.89
(1 year warranty, we have sold hundreds of these with excellent reliability and few warranty claims)
OEM JM rebuilt starter for Yamaha 701 289.80 (on backorder)
*Tested to work and includes a 6 month exchange warranty.
(water intrusion thru nose is not covered.)
*Add extended warranty for 1 year 20.
JM OEM Yamaha 701 starter 159.80
(clean freshwater starter, cleaned, inspected, polished nose, new nose Oring, lubed and tested, 60 day exchange warranty)
New SBT Hi-Torque Starter 149.90
(1 year warranty)
Fits Yamaha 650, 701, and 760cc motors
*add SS allen starter bolt install kit 5.
(stainless allen bolts with locking and flat washers)
Yamaha 800 (XS1200), 1100/1200/1200PV, 1300PV Starters
New ProTorque GOLD 800/1100/1200 starter $239. sale 178.89
(1 year warranty)
OEM JM rebuilt starter for Yamaha 800 PV, 1100/1200, 1200 PV 259.
JM OEM Yamaha 800 PV, 1100/1200, 1200 PV starter 129.
(clean freshwater starter, cleaned, inspected, lubed and tested, 60 day exchange warranty)
Kawasaki Starters
Kawasaki starters fit 650, 750, 800, 900, 1100, and also Polaris Octane
OEM JM rebuilt starter for Kawasaki 650/750/800/900/1100 209. (limited availability)
*includes a 6 month exchange warranty.
New ProTorque GOLD Kawasaki 650/750/800/900/1100 starter $239. sale 178.89
(1 year warranty, we have had great reliability with these)
JM OEM Kawasaki 650/750/800 starter $99.
New SBT Hi-Torque Kawi Starter 99.95
(1 year warranty)
Starter parts:
Replacement Starter nose O-ring OEM 7.95
Replacement Starter nose O-ring a/m 2.39
Starter OEM rubber seals 8.90/ea
(seal between center section and front and rear sections- 2 needed)
Bendix (aka: starter drive, idle gear comp.)
Again, aftermarket bendix just aren't up to OEM quality, but new oem are really expensive. Failures of OEM bendix are usually due to water intrusion or the inner metal weight plate ears breaking off allowing the weights to move around, and then break their locating spring allowing bendix to stick open.
JetManiac OEM bendix are inspected for inner weight plate having all 3 ears intact and replaced if needed, gear teeth and end surface condition, bushing ends are inspected and polished, finally they are cycled repeatedly to check front reverse drag and action, and lubricated with special Corrosion X HD lubricant protectant. Many are rejected for various other issues. Only nice clean ones are used.
(bgrade cosmetic available for less)
**If you have had bendix issues or are building a new motor, also make sure to check the soft bushings in the crankcase and inside the flywheel cover. Bendix should go in relatively tight and not rock much at all from side to side. The case side is especially prone to wear.
JM OEM bendix $146.50
*Tested/inspected/cleaned/lubricated/4 month exchange warranty
(water intrusion is not covered.)
New OEM bendix $528.99 sale 369.
Bendix installation parts:
Bendix bushing OEM- for crankcase or flywheel cover 17.95
Bendix bushing a/m- for crankcase or flywheel cover 6.95
Bendix front cover spring 11.95
Bendix front washer-smaller, thick for each side of front cover bendix spring- OEM 2.99/ea.
Bendix rear washer-larger, thin for bendix to crankcase -OEM 6.99
Bendix repair parts:
Yamaha OEM bendix weight spacer plate 19.99
(Replaces frequently broken internal plate that spaces the 3 weights. Broken ears are common and one of the causes of the dreaded 'bendix grenade.')
OEM bendix internal spring to hold weights 17.99
Billet Flywheel Covers
JetManiac anodized billet Yamaha flywheel cover 179.95 -Black only in stock
*Reusable Oring included.
*These flywheel covers fit Yamaha 650, 701,and 760 cases with OEM 650 6m6, 701 61x, or 701 62t electrics or MSD total loss setups.
JM SS allen head flywheel cover 7 bling bolts/washers kit $11.95
Dowel pins for cases to flycover 3.59
DASA billet flywheel cover 179.95
JetManiac
Stoked
orlando
Start/Stop Switches and Lanyards
index.php
Yamaha new OEM SJ start/stop switch assembly $275.99 sale 213.90
(Includes new lanyard, Fits all years SJ from 1990-2020, works for B1 also)
Yamaha new OEM SJ start/stop switch assembly $249.99 sale 203.85
(Without lanyard, Fits all years SJ from 1990-2020, works for B1 also)
index.php
Yamaha OEM SJ start/stop switch repair harness assembly $132.99 sale 111.89
(This is the complete s/s/s wiring harness and all new switches assembly except the plastic housing on the bars. Fits all years SJ from 1990-2020, works for FX1, B1 also)
Used OEM start/stop switch 78.80
-Sitdown length (shorter than SJ) harness
-lengthen harness and use in SJ, use for parts to repair SJ switch, use in B1 or sitdown Yamaha ski
(all functions tested, rubber lanyard switch boot inspected, 30 day exchange warranty)
Start/Stop switch parts
index.php
Replacement OEM Yamaha Start/Stop connectors 13.90/set
Ebox Start/Stop switch SJ OEM ebox side harness -new $96.99 sale 86.95
Replacement Kawasaki OEM Start/Stop 4 pin connectors 16.95/set
(1 Male and 1 female 4 connector housing for switch side and for ebox side, 8 crimp on connectors, and 8 rubber seals)
Green OEM replacement start button $15.99 sale 13.98
Red OEM replacement stop button $16.99 sale 13.95
Thrust EZ start billet switch top for Yamaha $118.89
Lanyards / Tethers
Floating Yamaha a/m lanyards 13.89
(red, neon yellow, black, or silver)
OEM Yamaha lanyard with neoprene wrist strap 39. sale 26.95
Floating Kawasaki a/m lanyards 13.
Battery box Battery tray
RRP X-LITE adjustable battery tray 195.
*Will hold a small battery from 4.625″ x 2.75″ up to a large battery 7.25″ x 4.125″ appx. The maximum height is 7 inches via the supplied stainless steel threaded rods or use battery straps.
Yamaha OEM SuperJet battery box (New) 39.99
Yamaha OEM SuperJet battery box (clean, used) 28.90
(includes stainless mounting hardware)
Battery straps 13.95/ea.
Shorter battery straps 13.95/ea
MSD battery quick disconnect kit $36. sale 23.80
JetManiac
Stoked
orlando
JM Custom Ebox builds and rebuilds
Ebox back is bead blasted
Painted with Black satin epoxy paint
New OEM ebox gasket
Ebox gasket sealed into place (helps prevent leaking)
Clean OEM components installed
JM custom Yamasaki ignition coil added
Finished Ebox
lazyt747
Cool Beanz
MI
Had my e-box rebuilt last season by JetManiac and he did a fantastic job. He even caught a tiny slit in my power cable that I did not even notice. +1 for a good seller that pays attention to detail.
I'm looking into getting my ebox reconditioned and buying some parts I tried sending you a pm please contact me when you get a chance :)
-Dennis
Sent from my SAMSUNG-SGH-I337 using Tapatalk
