Custom/Hybrid pole bushings for custom pole
Im in the middle of making an aluminum pole. The last part of the puzzle is the pole bushings.
I have gathered that they are not all the same, but what ones are better than others and why? I need to decide what rout to go. I would like them to be replaceable and readily available.
Opinions on what bushing to go with? AC racing? RRP? oem?
And here are some pics if your curious. its -1.5 from my sn pole and set up to fit a RN style bracket. I have one more complete ready to be welded. going to see how i like the length and go from there.
2014-03-09 17.26.06.jpg 2014-03-07 01.20.56.jpg 2014-03-07 01.20.16.jpg 2014-03-07 01.19.49.jpg
Thats a good looking pole! I actually used PVC fittings but shaved them down to fit in the holes snug. I was leary about them breaking but so far they are solid as a rock and hold the pole with little to no movement. Sometimes you just have to get a little crafty and walk through the hardware store with your eyes open.
looking good. i cant chime in on the bushing but im curious are these going to be for sale to the masses or are you just making one for yourself?
i may consider selling one. as of right now i have another pole that is ready to have the tubes welded. i am going to ride this one and see if i want to go shorter or longer on the tubes and sell what ever one i dont use.
i am definitely not going to produce these to sell though. they are a lot of work to make. I made it on my spare time at work. didnt cost me anything so i figured i would give it a shot.
I made a pole similar to that and the stock plastic bushings lasted one season. It has bronze bushings I got from a local bearing shop and it looks better and feels tighter we will see how long they last. They cost like 5 bucks altogether. I think I used 1" od and 3/4 Id. But I had to drill out the I'd to get the pole bolt through.
what is the exact size of the pole bolt? it is metric correct? I might just have to go that rout. the stock bushing do seem to be pretty week.
and thanks for the compliments. I cant wait to see what it looks like on the ski.
Sorry I told you wrong. The bushings were 1/2 I'd 3/4 od. The pole bolt is 14 mm or .550.
finally finished my pole in case you guys were curios. i went with the oil infused bronze bushings.
