better than a advent ?cauz im looking betwen and advent ,cdir9 or the new blowsion one,does the cdi r9 give good power?Excellent, Bulletproof. I have had one for about 6yrs, have even hooked the power up backwards. Wired correctly again, it still works perfectly. You will need a switch or module to disconnect the power when not in use as it will drain your battery within 24hrs.
I had a T3 before the 9R, it didn't work from day one. Sent it back to Advent under warranty, BS for a couple of months, never got it back replaced, so I won't touch Advent now.
