I read all the posts i could find on here by using the search function and can't find what i am looking for. See plenty of threads on how to run the lines on a 701 or 750 but not sure how the lines run on an x-2 with a 650. my guess is pump line into the manifold like stock, one from head to front of head pipe then from here I am not sure. there is a stock line that was on the rear head pipe stock fitting that runs back to the bulkhead is this a dump line? do i run a T in this line and send the other end to the stinger? there was a crappy skinny line running from the stock head pipe to a bypass what do i dump into this fitting.
