Lost spark while just cruising....
so, were out at the inlet this past sunday....semi knarly conditions, one of those days when you are thinking to yourself "man, glad my boats' runnin' good today.....glad we dont have any tow-in's...)
5 mins later
my boat just shuts down...very abruptly, and out of the middle of nowhere....
so, after a slightly hairy tow to the beach and some muscle work we got the boat back on the trailer (btw, big props to butti for going back to the ramp 2+ miles, and bringing me all my stuff.....:woot: )
get her home, and she's got no spark.....
Here's what Ive tried:
different s/s switch--nothing
swapped out MSD for another--nothing
swapped out 2nd MSD for a stocker--nothing
changed coil--nothing
the inside of the E box was absolutely perfect...bone dry, no salt, no signs of water intrusion.....
Butt and motosurfer came over last nighht and they ohmed out the stator for me.........
I believe the greens tested out to 1.5 ohms....same as another stator I had sittnig on the bench.....
Ive just never had such an ignition failure when the boat was actually running, and running like a champ none the less.......
so, as of right now I have a ski that has yet to be flushed.....that was towed it and defintalty took in some water.....ive been turning it over 2-3 times a day and of course filled it with a bunch of pre-mix and straight oil....This no spark thing is really getting in the way of my de-foam project as I dont want to pull the motor until I get her running again!
Anyone have any ideas?
bad connection where start stop plugs into the electrical box......... also, check the wires going through the grommets into the electrical box, I had this happen last spring, it was giving me intermittent spark.......... wiggle the wires where they go in, you may can feel a break right where it goes through the rubber.
sounds stator related. the resistance of the green wires has very little to do w/ spark.
also, check the grounds in the box.... and not just visually. i had a bad ground in my ebox a few months back that wound up being a broken wire. the wire 'looked' fine, but the conductor was broken underneath the intact insulation.
SkiDaddy
Just Havin' Fun!
Orange City, FL
Maybe just switch the entire electrical system w/a running one (I know you have the parts/can borrow) one section at a time (e-box, stator assy, s/s switch) until it runs & you can isolate where the problem is. At least you could run it in the pond for 20 minutes to chase the rust away....:cat40:
RoyalFlush@PCB
Shootin' The Crap
PCB
It must be some karma with that particular ski. When I first put it together, I only got about three or four rides in and the bendix bushing in the case broke which caused the bendix to be misaligned, therefore the ski would not start. I ended up taking the motor out and tearing it down so I wouldn't lose the crank.
lol.....ive had this motor/electircs combo going now since august....been perfect, not even so much as a hiccup or fouled plug.....
before that, I ran it from the previous january with no problems.......
I will mess a little more with the electrics tonite, but I think if I cant get it fixed by tomorrow night Ill just pull all the electrics and replace for the sake of running the motor on monday.....
I will go and look for broken wires inside the conduit in the ebox, but is there any specific wire I need to look at?
im guessing I dont need to mess with the regulator...nor the solenoid...right?
btw, im no good with a meter...........I usually fix ski's by swapping parts :boggled:
SkiDaddy
Just Havin' Fun!
Orange City, FL
I had the wire break where it went into the stator winding - it had been just barely hanging on apparently...
Given your ability with a meter, you might want to consider boxing the whole electrical system up & shipping it to Jet Ski Solutions & letting John diagnose/fix things.:burnout:
i wondered if maybe somehow the edge of the flywheel nicked one of those wires....would be pretty uncommon, but I could see it happening......
who needs JSS....I got MOTOSURFER!
appreciate all the offeres on the parts homies....I should have everything needed though.......dont forget your talking with an OG parts whore :cool2:
RMBC Freeride
Vintage
Pueblo, CO
Do you still have the overheat sensor connected and running to the head? If so,... good. If not, the only ground connected to the e-box is the one in the stator harness. if that gets broken or corroded, then no sparky.
If you dont have the overheat sensor in place, run an extra ground from the blok or battery directly to the e-box mounting tab. And see if you have spark? Easy test.
Oh, and get that thing fixed & at least keep it running until Saturday the 9th when I come to visit!!!! :fingersx: :fingersx: :fingersx:
RMBC Freeride
Vintage
Pueblo, CO
Hey, some ppl swear by them for safetys sake and some throw them in the trash immediately (or when they get an aftermarket head). I was just covering all bases...
Mine go in the trash.
the overheat sensor isnt grounded to the head.
