SXR Rubber bushing on drive shaft
Jersey
It's not the bushing that goes in the end of the prop, it's a lot bigger and it seems to have made its way into the center of the where the intake grate is on the shaft. It's about 1 to 2 inches long and it's thinner on the end that is closer to the hull. Did this come out of my bearing carrier can I just slid it back up any advice would be great.
djkorn1
kidkornfilms
Cleveland Ohio
sound like the one that came out of prop. Take a pic.
Jersey
Are there any other rubber components that can work there way out onto the drive shaft? I looked at the manual and could not see any...
Jersey
checking in on this one, after looking again at this it is the rubber nose cone for the prop, I thought it fell off, it has just bee moving up and down the drive shaft, I check after two rides this weekend and it was in different locations each time. So should I just leave it or work it back into place and put a tiny bit of silicone on it to hold it in place?
Thanks for the advice thus far guys!!!
yamanube
This Is The Way
Staff member
Mandalor
I had the same issue on a superjet, I pushed it back in multiple times and every time it would come out of the impeller sometimes causing cavitation (when it would make its way up the shaft). I ended up putting on a billet one from impros or somebody, had the same issue, they said they had redesigned them to use two screws and if I sent mine back, they would send me a new one. I ended up just taking it off and never ran one, never had an issue after that.
