- Southern Virginia
Im currently building a 701 for my ski and I have torqued all the bolts down properly and everything in the cylinder is new bore (2mm over), rings, pistons (sudco), and gaskets! I only get 90 psi for compression!! what could be wrong?!?! Also both cylinders are at 90 psi. Also I have no idea if the compression guage is working right or not i barrowed it from a guy at work it uses an o-ring to seal it could that be a problem?? I was told that the piston to cylinder wall clearence was suppose to be .005 in but i can go all around the piston with a .006 filler guage but nothing any higher could that also be the problem?? I did lube everything before installing with some Yamalube i had from last season
