Super Jet waveraider parts on a superjet?
mike b
California
Hey guys, was wondering if some waveraider parts would fit in a superjet. Either SN or RN superjet, doesn't matter. I know I can use the engine, and ebox, probably even the midshaft if i wanted to spend the time shortening it. My main question is can I use the pump section on a SJ. I know ride plate and intake grate probably wouldn't but the SJ hull im looking at already has those. Just wasn't really wanting to buy a pump if a perfectly good one is right next to me. Any links would be appreciated or any thoughts/advice.
if its a 701 raider the pump is a 144 pump like the sj i believe but the housing section doesnt have threads since it threads into the impeller duct on a raider so you would have to helicoil the housing section. driveshaft length is different i'm pretty sure.
jetmaniac could confirm all this and set you up with the right length d/s. he is like google for jetskis
mike b
California
Yea i knew driveshaft length was longer on the raider, what about the pitch of the impellor does anybody know if its good to go or if id need to swap for a better pitch? And would it be smart to do an oil blockoff kit or keep it the same as it comes out of the raider? thanks fo r the help!
JetManiac
Stoked
orlando
The pump will transfer over, like surfjunkie said the impeller housing will need to be helicoiled and long pump bolts shortened. You will need a pump seal, a shorter pitched prop, and the driveshaft modded to SJ length.
Raider midshaft housing fits in a SN 94-95 and all RN, but shaft need to be changed.
start/stop switch can be used but harness needs to be lengthened. Various other parts can be used as well- waterbox straps, etc.
mike b
California
Alright. Thanks for the help guys! I have a few ski project this year for myself and some buddies so im sure you'll see me asking for help again ha.
