Hello
I have a dasa stock stroke dasa 771 pv engine with an oem pump with a 10/16 hooker in it.
Would a solas concorde 13/15 4mm cutback work better with my engine setup?
I'm trying to get a little more bottom end hit out of it.
Thanks/Tomas
Ok I will change to the solas thank you
I also have a ATP stubby cone lying around, is it something worth putting in to help with the bottom end?
Do you think it will be better then a 10/16 hooker or the solas?i would repitch the hooker 10/16 to 9/15 or 9/16 for better results.
Hey guys im new to the stand ups and just bought a super clean 89 650sx and wanted to put a new impeller in. im looking at the Solas 13/18 with a R&D scoop grate. is this a good impeller for low end? Thanks!
