- Stockton CA
Good call by Mr. Clemmons. Could'nt the "clean" piston look like that from water ingestion? Oring or head gasket good? Is compression even?
So what should try next? The electronics came out of my 650 motor and they are good. Maybe pop off test the carbs? Maybe one spring is a little bit stiffer?
looks like lack of ignition, possibly cdi, plug wire or possibly a air/fuel too rich preventing ignition. Just a guess since its hard to tell just by a picture.
Please refrain from posting the wrong information because you clearly are still learning.
