waxhead
wannabe backflipper
- gold coast
Novis with out a doubt
How come all of these carbs are annular discharge I was reading a groupk tuning guide and it said annular discharge carbs are bad for low end because you can't get the correct velocity through them consistently and that the bomb sight style carbs are better. Any input on this?
So they don't sell BlackJacks where you live?
yes they sell them here. They are a good carb. But the question was about the best carb. In my experience the black jack is not anywhere near as good as the novi
yes they sell them here. They are a good carb. But the question was about the best carb. In my experience the black jack is not anywhere as near as good as the novi
If you ever want any happiness in your life you WILL quit reading Group Kmart's B.S. !!! You need to figure out who the smart people are here on the X and listen to them.
As far as carbs go, Sjetrider said it best, the best carbs are the ones that you KNOW you can get great support with!!!
Clearly I have no idea how to tune carbs, Thanks Gill run along now[/COLOR]So are you saying you don't know how to tune BJ's or are you saying that Art is too smart to mess with you?
GroupK is not reliable source of information? Or too racing based to be freestyle? or both?
I did notice some of there testing strategies were kind of silly and impractical. More of a weekend warrior high speed straight runs kind of testing than a performance race or freestyle deal.
Here are the facts,
IF you tell Art your COMPLETE setup and then buy carbs from him, you don't have to know how to tune them. Art sends them to you, you bolt them on, and you have perfection!!!
Fixing to start my winter build, I got everything pulled out. I got the hull weighed w/ oneway valve, aluminum pump shoe,foot holds, still turfed, with extended turfed rails, 121.4 pds, Hood w/home made hood liner, hand holds and breather tubes, 21.4 pds, handle pole with blowsion turnplate, bars and umi aluminum pole bracket 19.6 pds, The hull seems to b a lil heavy but not sure what a good stock hull weight is suppose to b. My plan is to shorten 3 in, defoam, Possibly makeing my oneway valve pump dump, and thinking bout pump dumping exhaust, not sure bout the exhaust. reinforce engine compartment, widden the tray, go with some adjustable foot holds. And possibly lowering stock hood, would like to go aftermarket hood, but will have to c how money situation goes, also wanting to get one of jet maniacs engines. Im also thinking of reshapeing the gunwales, maybe like a superfreak, Or possible like the lightweight hull,
How does he account for realitive air density for people in different locations Gil ??. Or do Black jacks magically not suffer from changes in air density like every other carb does. Do you go down to your ride spot and measure the water temp so he can know the exact temp your engine runs at in those conditions. The fact that you think he can set a carb up to run perfectly over the phone really tells a story about what you are happy to accept as perfection.
