- amarillo ,tx
Fixing to start my winter build, I got everything pulled out. I got the hull weighed w/ oneway valve, aluminum pump shoe,foot holds, still turfed, with extended turfed rails, 121.4 pds, Hood w/home made hood liner, hand holds and breather tubes, 21.4 pds, handle pole with blowsion turnplate, bars and umi aluminum pole bracket 19.6 pds, The hull seems to b a lil heavy but not sure what a good stock hull weight is suppose to b. My plan is to shorten 3 in, defoam, Possibly makeing my oneway valve pump dump, and thinking bout pump dumping exhaust, not sure bout the exhaust. reinforce engine compartment, widden the tray, go with some adjustable foot holds. And possibly lowering stock hood, would like to go aftermarket hood, but will have to c how money situation goes, also wanting to get one of jet maniacs engines. Im also thinking of reshapeing the gunwales, maybe like a superfreak, Or possible like the lightweight hull,
