If it gets deleted or you cant see it its a 650sx "with a 800 big bore kit", is it even possible to punch a 650 out to 800?? and if so why would it be worth it?? http://pittsburgh.craigslist.org/boa/3701230709.html
Big boring a 650 cylinder to anything near 750cc is obviously not doable. Installing the longer stroke 750 crank in the 650 cases is also not doable (won’t fit), and installing the 750 cylinder on 650 cases is a setup wrought with lots of undesirable technical compromises.
i have a 1992 kawasaki 650sx standup jetski for sale. has 800 big bore kit in it, west coast pipe, extended ride plate, intake grate, pole spring, stainless prop, mariner dual cool head, high flow intake. runs good, but having some cooling issues. will run all day on the hose, but when put in the water it overheats after about 10 minutes. according to some of the research i've done, it just needs the dual cooling mod done to it. you just tap another cooling hose to the pump and separate the engine and exhaust cooling with the westcoast recommended hose routing (on their website). its about $10 worth of hardware you can get at home depot. i just dont have time to do it right now. have a bunch of spare parts including 2 spare motors (1 blown and 1 usable), prop, exhaust, stator, shaft, pump, and more. 1200 cash or make me a reasonable cash offer....email or call/text 484-686-four seven four one. i have all paperwork for it to be legal.
ur post got me searching craigslist. Check this out. Its a stock square that does 70 mph... http://sandiego.craigslist.org/nsd/boa/3731955142.html
1998 sxi pro, In excellent condition with very low hours, always stored in heated garage. Built as a back up race ski with no expense spared when built. aluminum handle pole,UMI steering and bars,Factory pipe exhaust with ecwi,, Billet Buckshot carbs(47MM) Carbon fiber flame arrestors and reeds,milled head,Multi point cooling and bypasses, hull has been weighted and trued,Skat impeller, R&D intake and ride plate. Garage dolly included.$3200. Call 603-315-1659
Freshly Rebuilt 1991 (square nose) Yamaha Superjet with rebuilt trailer for sale. New everything! NEW battery, bilge pumps with switch on deck, intake grate, ride plate, aluminum handle pole. New Blowsion deck mats, rub-rail, nose and sponsons! Engine rebuilt last year (135lbs per cylinder)! Fresh paint and other cosmetic touches! Great Ski for all around use and is very reliable! Trailer has new tires, wiring, lights, paint, jack, and tongue. Email for more pictures. Ski is located in Baton Rouge
I scan craigslist daily just for laughs. Anybody need a 91 superjet? Freshly built motor with 135psi per hole? Only 3k! http://batonrouge.craigslist.org/boa/3719552346.html
