Freestyle PFP+OEM hull. IF YOU HAVE DONE IT, I NEED TO TALK TO U.
This was for in an x2 but anyways. If anyone wants it $200. Going back to a b pipe on a PHP 898 because I like the larger gas tank. Couldn't stand the kart tank
Except I suspect Gil runs his carbs with the pumps towards the cylinder. Also, the problem is more with the intake manifold than the carbs in my experience.
MikeyB
H2O-Addict®
Michigan
Talking with absolutely zero experience here, but any chance of flipping the box around so the straight outlet is on the bottom pointing towards the rear?
Not possible. The chamber exit is only 1-2 inches away from the wb inlet, so that has to be straight and in the original position
98gti
C@R H@ul3R
NW FL
Come on now, where is Gil going to get pubic hair?
(Without violating his parole)
At the next Alabama freeride, Gil is very persuasive when it comes to getting you into a boat ramp porta potty, fool me once shame on you Gil, fool me twice shame on me.
Gil Hope this helps..... 08 SJ Powerfactor pipe and water box on a 12mm ADA Gomez Powerplant. Only thing i did was drop the exhaust tube height when i re foamed the tray. I also picked a section of the stock exhaust hose that used the stock contours to get as much clearance at the carbs. Mine clears no problem.
O btw I also angled my waterbox holder / box ever so slightly to point out towards the side of the hull rather than directly at the intake manifold. If I can help you any more let me know. Kenny
GIL
Power In The Hands Of Few
Cullman AL
Kenny, I really appreciate your help and input!!! I've been trying to utilize my stk battery tray with the holes re-drilled to move the battery tray as far towards the right side of the hull as possible. I think if I build a tray for the waterbox I can get it kicked out further towards the side of the hull.
